I would have thought the part number on the injector would give you a fair indication, as far as I'm aware bosch piezo are numbers 0445115, 0445116 or 0445117. Not always easy to see part numbers though
Thanks for the help guys, I've seen it mentioned that the leak back is a good indicator as Piezo injectors often have leak back going sideways rather than upwards would you say that is a good indicator?
Are there visual ways to identify or is it just researching the specs of the engine?
Hello. For a Bosch piezo injector, diesel fuel is supplied from above, and for an electromagnetic one from the side. And for an electromagnetic injector, there is usually an outlet for fuel backflow from the center of the electromagnet. The photo shows a Bosch piezo injector.
