Pressure transducer and Noise-vibration Kit
IA1991
Post by IA1991 »
IS the Pressure transducer and Noise-vibration Kit compatible with all the scopes?
iam planing on buying the PicoScope 4425 Standard Kit, 4x20 MHz 0.4 GSPS.
will it compatible with the above mentioned kit?:?:
Re: Pressure transducer and Noise-vibration Kit
The Pico Pressure Transducer and NVH kit is compatible with all automotive PicoScopes including the 4425 Standard kit (which is a great choice of kit)
The pressure transducer can also be used with any Scope too including, Pico Test & Measurement scopes or non-Pico scopes. You may/will have to create a custom probe or manually convert the output voltage of the transducer into pressure units
The NVH kit however is only for use with all automotive PicoScopes via the Pico Diagnostics software which you can download for free here https://www.picoauto.com/downloads (version 6.14.25)
IA1991
Post by IA1991 »
Thank you for reply Steve!
i just got my hands on the picoscope 4425a and cannot wait too get started!
mpalazzo
Post by mpalazzo »
i got on this thread and make an additional question :
The Pico Pressure Transducer and NVH kit is compatible with all automotive PicoScopes, so it will be with the 3423 am I right ?
Will it be useable ( 3423 ) with the Pico diagnostics software ?
I want to buy an used 3423 to stay on budget and add an NVH kit to make my field service engineer in automotive more effective ( you know sometimes in the workshops there is not the chance to have a scope and proper kit fitted )...
Thank you very much
Cheers
Matteo P.
Hello again Matteo, yes you can use your 3423 with Pico Diagnostics and NVH
It will also function with the pressure transducer, the waveform library (with PicoScope 6 Automotive) and PicoScope 7 Automotive software
