Goodday! Tyrone here from New Zealand. I've acquired my NVH kit recently and started mucking around with it. I've successfully set it up and recorded a 5 minute test drive/data capture and saved it. I arrived back to the workshop and played back the recording and it appears the NVH software saved only about 48 seconds of the recording.
Is there any way of saving and playing back the full length of the recording for future testing. Any help would be appreciated. Regards Tyrone
Your NVH software can capture up to 500 seconds of data but will only ever playback the visible data on screen.
It sounds like your capture time was set to 50 seconds, yet your road test lasted 5 minutes.
Unfortunately the NVH software behaves like a chart recorder, as the data moves from right to left, any data that leaves the screen (on the left) is lost forever. (See below)
Saved Signal
To increase the signal history, please see the video below:
500 seconds is a lot of data to save and move around Tyrone so once you have found the offending data, you can then Export the desired area of the signal history to a PDdata file so reducing your file save whilst retaining that all important NVH capture.
The following link will help: topic21639.html (Look at "Improved Export Options")
