Ranger 3.2 valve timing problem
Twins
Post by Twins »
I have 2013 Ford Ranger 3.2L Diesel. The fault code is P0341-62 and will not clear.
I have all the valve timing alignment tools and have checked it multiple times, but from the good known scope patterns it appears that my timing is out. I have fitted a new crank and cam sensors but still get the same code about 2seconds after start.
What am I overlooking here?
https://drive.google.com/file/d/1_23LT6fSUd6Gphr1Wup9747P7mtjGtbq/view?usp=sharing
Ford_Ranger_2011_20200528-0001.rar
(27.28 MiB) Downloaded 966 times
Ford_Ranger_2011_20200528-0001.psdata
(27.28 MiB) Downloaded 481 times
(27.28 MiB) Downloaded 397 times
foster ace ford ranger 3.2 cam & crank.psdata
(2.35 MiB) Downloaded 692 times
FORD RANGER 746RXC START UP CAM CODE P1174.psdata
(4.55 MiB) Downloaded 540 times
Hudsonautomotive
Re: Ranger 3.2 valve timing problem
Post by Hudsonautomotive »
Hey mate did you get to the bottom of this problem? I have a vehicle with the same code here.
Dcunning35
Post by Dcunning35 »
The pcm learned values will need to be reset after any work on the static timing.
The Ranger ,puma diesel engine times the crank on the front not with a pin in the ckp hole.
The ckp bracket has elongated holes and could also be out .
