Mitsubishi L200 FRP Waveform
Burt_100
Post by Burt_100 »
Does anyone have a known good FRP for a 2009 Mitsubishi L200 2.5 TD, I have managed to get the attached waveform but i'm not sure if it is good or bad as I have no comparison, Can anyone help out? The pickup has an intermittent miss at around 2500 - 3000 rpm under full load and is very slow to rev.
L200_FRP.psdata
(519.08 KiB) Downloaded 319 times
Re: Mitsubishi L200 FRP Waveform
Burt, have you checked the waveform library?
Burt_100
Post by Burt_100 »
I have checked the waveform library but can’t see anything the same or similar
iATN
Burt_100
Post by Burt_100 »
I don’t have iatn
vasek
Post by vasek »
Hi.
If it's useful.
Burt_100
Post by Burt_100 »
Looks good thanks have you any idea of rise time from idle to full fuel pressure
ronw38
Post by ronw38 »
Check Pico library Videos Frank Massey's top ten tests #7 it will reveal all . Cheers Ron
This one;
https://www.picoauto.com/library/videos
