Protection
Carl
Protcetion
Post by Carl » Sun Mar 16, 2003 9:26 pm
I have a question
When the secondary leads are connected, what will happen if the HT lead is pulled off the spark plug, or the HT lead is open circuit and the channel gets zapped? Is there any protection for this scenario? :twisted:
matthew
Post by matthew » Wed Mar 19, 2003 12:50 pm
Hi Carl,
The HT Lead should never have a direct electrical connection which would allow it to be 'zapped'. If there is potential for this ever to happen, then the equipment is not being used safely.
The unit is protected from major damage up to 100V dc, however, you can only measure up to 42V dc for personal safety.
Best Regards,
Matt Everett
Pico Software Engineer
Carlos
Re: Protcetion
Post by Carlos » Tue Mar 25, 2003 2:28 am
Carl wrote:I have a question
Hello carl!
Ouch I see what you mean. I went to check the connection of the HT clip on the main coil lead with the engine running, a spark jumped through thelead insulaion to the connector and I got a zap. I dont think it caused any damage to the unit :roll:
Regards Carlos
matthew
Post by matthew » Wed Mar 26, 2003 2:25 pm
I've checked this out with the manufacturer, and the lead is designed to dump these sparks to ground, so there should be no problem with damaging the unit.
If you want to avoid this happening anyway, just switch the engine off first.
Best Regards,
Matt Everett
Carl
Post by Carl » Thu Mar 27, 2003 9:17 am
Thanks that's all I wanted to know
Regards Carl :D
