Hi, hoping someone can help!
Peugeot boxer 3.0 2011 4050kg
No speed signal to Speedo. The instrument cluster has been replaced, body control module, ECU and abs module have all been checked. No speed sensor on gearbox. Vehicle speed is reading as 0. All 4 abs speed signals are working. Intermittent hill hold and traction control loss, can be turned of and takes about 30 mins to come back on.
There is no speed sensor on the gear box. I assume speed signal is one generated by the ABS module. I haven’t found the right wiring diagram yet to test the signal at the cluster?
