Peugeot 207 1.4vti
Burt_100
Peugeot 207 1.4vti
Post by Burt_100 »
I have a 1.4 vti Peugeot 207 that is pressuring the inlet manifold and I believe that the timing is out. I have attached a waveform of the crankshaft, and inlet and exhaust cam sensors, Can anyone advise if the timing is correct?
Johnny
207_misfire.psdata
(6.07 MiB) Downloaded 345 times
Re: Peugeot 207 1.4vti
Have you tried the waveform library?
Burt_100
Post by Burt_100 »
Yes but cant find anything
This image is taken from a Peugeot 207 1.4 VTI - I know it's not a picoscope psdata file that you can play with, but by looking visible at the image - I would say the cam and crank timing are out of spec.
Peugeot 207 1.4 VTI CAM AND CRANK RELATIONSHIP
Best regards
Kim :wink:
vasek
Post by vasek »
One more.
Burt_100
Post by Burt_100 »
I am almost sure it needs a timing chain I just need to get the chain off and compare to the new one to verify, I carried out a pressure test on the cat and all was good, Thanks so much to everyone for all the help
