I have a 1.4 vti Peugeot 207 that is pressuring the inlet manifold and I believe that the timing is out. I have attached a waveform of the crankshaft, and inlet and exhaust cam sensors, Can anyone advise if the timing is correct?
Johnny
This image is taken from a Peugeot 207 1.4 VTI - I know it's not a picoscope psdata file that you can play with, but by looking visible at the image - I would say the cam and crank timing are out of spec.
I am almost sure it needs a timing chain I just need to get the chain off and compare to the new one to verify, I carried out a pressure test on the cat and all was good, Thanks so much to everyone for all the help
