I have audi a4 B6 with p1347 cam sensor 2 versus crank sensor wrong correlation, the customer told me that he had new original timing chain kit installed in his vehicle before 70k KM. Now the error is not present and i am suspecting bad cam sensor but if someone have some advise or known good capture it will be great
now i have known good capture (thanks to Dan Nielsen from FB pico group) from 2007 s4 but i think its the same there are only two engines with same timing for this chassis. now i think for timing problem but why the code is not there all the time? any suggestions. i will measure time from point of crankshaft to see which cam sensor is out of timing because there are four chains ou and from cold start there is metal knock from bank 2 i think for 1 second
