analyzing Relative compression results
CycleImp
Post by CycleImp »
Is the any way to get useful data from a relative compression test on an uneven firing engine like a V Twin or V 4?
Re: analyzing Relative compression results
Regrading "useful data" from your relative compression test could I ask if this is to determine the offending cylinder?
If so, then the following Case-Study from Ben describes the approach taken for a Parallel Twin engine.
Whilst this is not your V Twin, the techniques describe the application of PicoScope and a current clamp to determine cranking effort (relative to compression) via the starter motor current draw.
Introducing a second channel to capture the ignition event of cylinder 1 will help identify each cylinder
CycleImp
Post by CycleImp »
Hi Steve, that is exactly what I was looking for, thanks so much. James
