freezing waveform
johnyp
freezing waveform
Post by johnyp »
Hello and well done with this amazing product.
I wont to ask you about the software.... while i using pico software on my pc often is freezing and i pressing stop then start , to continue seeing the waveform.
Liteace
Re: freezing waveform
Post by Liteace »
Ongoing problem that I also have had for a long time,, very slow sorting this one out,, I hope soon p
VASTech
Post by VASTech »
Hi guys!
Even if I have a good hardware resources, I7, sometimes i experienced myself this problem. It`s most like a software - driver issue. Hope someday will be fixed. This is very annoying ... sometimes
Liteace
Post by Liteace »
VASTech wrote:
Mon Oct 21, 2019 2:21 pm
sometimes? all the time, we cant have a scope trace on screen that freezes, that's the idea of the scope, look at the screen to find the glitch, screen freezes and we miss it, whats the point !
I though this was fixed with latest release?
It doesn’t happen to me anymore .... so me confused about your issues?
Liteace
Post by Liteace »
This is what Ive got on a i5 toughbook and still getting the lock-ups
Post by Autonerdz »
Yup. 6.13.6.3775 is a broken build. I suggest you update.
Not aware of any such issues with the current build but it does have a bug with the RPM/Frequency measurement box.
Post by Martyn »
I would also suggest that if you did replace the USB connector on your scope that you look carefully at the repair. Any issues with this and the PC/Scope may not be seeing the data they expect which could cause problems.
Liteace
Post by Liteace »
The screen lockup has been happening for months, well before the USB problem
here:
Post by Liteace » Thu Jan 17, 2019 9:05 am
https://www.picoauto.com/support/topic21658.html#p98167
I did check in the help for updates and it said the software was up to date.
definitely no issues with PC as both toughbooks (built to last) with screw in USB connector / adapter
If I was to change that USB, I will, as I always do double check my soldering, I do quite a bit of eeprom, mcu and mem chip work
that's fiddly work so a massive USB connector wouldn't be a problem.
I had nothing to do with design, manufacturing of the hardware or play any part in software development, all I done was bought it hoping it was going to be a reliable tool but unfortunately not much is built to last these days, its more down to greed than quality
Post by Martyn »
Unfortunately the online service is not currently working for all customers.
The latest software version is always available directly from the website Latest Version, and is released there before it is added to the online update service.
