probe for fuel ethanol percentage sensor
Marciooliveira
Post by Marciooliveira » Thu Sep 05, 2019 5:18 pm
Hello everyone I would like you to help me create a custom probe for use with this ethanol percentage sensor, it has 12 volt power and outputs in 50 to 150 hertz, I would like to turn this frequency into percentage from 0 to 100 % as i live in brazil all our vehicles are flexfuel and it would be very useful for me to use peak 4425 to see the percentage of ethanol in the fuel
sensor ethanol.jpg (3.74 KiB) Viewed 946 times
kona
Re: probe for fuel ethanol percentage sensor
Post by kona » Thu Sep 05, 2019 7:33 pm
Hello ,
Input units for PICO can only be:
- microvolts;
- millivolts;
- volts;
- kilovolts;
You have an output signal - hertz.
It seems you can’t just create a probe for your sensor.
It is possible to create a script, but it is more complicated.
Marciooliveira
Post by Marciooliveira » Thu Sep 05, 2019 7:42 pm
I wanted to create a 0% to 100% output
Post by Martyn » Fri Sep 06, 2019 6:15 am
If you set the channel coupling to Frequency for Channel A, the channel itself will return a signal between 50Hz and 150Hz
You can then create a Math Channel that is simply A-50 and set the units to % , just import the Ethanol Percent math channel
Ethanol Percent.psmaths
(366 Bytes) Downloaded 85 times
Marciooliveira
Post by Marciooliveira » Fri Sep 06, 2019 11:24 am
Thanks Martin for the support was of great help
