Intake vaccum with wps500
Jesper
Post by Jesper » Sun Jul 07, 2019 9:14 am
Hello.
I am new to the WPS stuff, so thought that i would play around with it. It is A 2,0 natural aspirated engine, with very light/small misfire sympthoms 1800 rpm.
I messure intake vaccum,idle, and i think that it looks suspicius that every 2. drop looks different, like the valve overlap is different on 2 of the cylinders. Can anyone clear that out. I think mabay the tappets is worn out, because of a tapping noise cold.
Best Jesper
Attachment one pico file.
Only one picture frame 1.psdata
(1.01 MiB) Downloaded 96 times
(1.01 MiB) Downloaded 77 times
landroverman1958
Re: Intake vaccum with wps500
Post by landroverman1958 » Sun Jul 07, 2019 9:45 am
Good morning,why dont you put the pressure sensor in the exhaust?that way you can see if you have any exhaust un eveness,or do an in cylinder pressure reading. :idea:
