PicoScope 7 Automotive
Available for Windows, Mac, and Linux, the next evolution of our diagnostic scope software is now available.
2 Channels will allow you to look at 1 Primary and One Secondary a a time or just 2 secondaries unless you add the Mixmaster 12-Channel Automotive Signal Mixer which will show you a parade of 12 cylinders Via 1 Channel of the scope.(1) Ignition -distributor type- primary and secondary readings;
You will need AMP Clamps capable of Starter Current and Charging Current. Channel 2 on battery to look at Voltage and then in depth examination of Diodes, Brushes in the Alternator.(2) Starting and charging; (3) Batteries, Starters and alternators.
