Volvo D5 relative compression
lastvagn8
Post by lastvagn8 »
Hi all,
struggling with a Volvo V70 D5 2004. It has problem with running rough and alot of soot in particulate filter. Checked for leaks and some injectors are replaced. Did a relative compression check and heard after some cranking that the engine ran faster.
According to the waveform it's alot less current after a little while.
Anyone have any idea?
Volvo_V70_Diesel_20190524-0001.psdata
(2.12 MiB) Downloaded 466 times
seafordmotors
Re: Volvo D5 relative compression
Post by seafordmotors »
Hi there,
Have a look at the cam shafts and hydraulic lifters. I believe this engine is prone to failures in this area.
This would lead to incorret calve opening and closure.
