2005 Vw Golf APP Sensor Normal or Abnormal?
AutoDiagnostic
Post by AutoDiagnostic »
This car came in with APP sensor correlation fault code and the sensor signal fault codes for 1 + 2.
The fault codes never came back even with 20km of driving.
I've attached the reading of both signal 1 + 2 of the APP sensor. This is with ign on, engine off. The downward spikes go away when I disconnect the ETC (Electronic Throttle Control) plug.
I'd like to know if the spikes are acceptable or not.
Cheers, Jack
VW Golf 1.6 APP new pedal.psdata
(370.35 KiB) Downloaded 519 times
