MAF Sensor problem
Ruler17
MAF Sensor problem
Post by Ruler17 »
I have a 2000 Chevy Silverado 4.3L V-6 that is coding P0102 & P0340. I have replaced MAF, camshaft position sensor, & rewired MAF connector plug, & it is still throwing those codes & blowing the Eng 1 10 amp fuse. Hard to start & when running it jumps on acceleration. I have checked MAF for power & signal & it checks. Also camshaft pos sensor checks. My question is how can you have power to those 2 components with a blown fuse?
Re: MAF Sensor problem
Post by Technician »
Check the wiring diagram. Is it possible that a short to positive is present?
