2013 Citroen berlingo 1.6hdi 9hn crank cam sync trace
Col24980
Post by Col24980 »
Hi guys, does anyone have a cam/crank sync trace please, I’ve physically checked the valve timing which is spot on but I’m still flagging p0335 fault code and non start situation.
I’m getting a good trace from both cam and crank but don’t have a known good to compare.
If I unbolt the cmp and hold it at an angle imitating retarded valve timing the engine fires up!?
vasek
Re: 2013 Citroen berlingo 1.6hdi 9hn crank cam sync trace
Post by vasek »
It should be the same engines:
Hello Col,
This engine was used in a number of vehicles as we know. The waveform library has a lot of cam crank references for this 1.6 HDI engine. I would start by looking up 1.6, Diesel and then select Citroen to start with and keep going till you have a pattern where the outputs look similar and compare this way.
Hope this helps and f you need any assistance with this let me know.
