Mercedes ML engine erratic shutoff
victor2k
Post by victor2k »
On a 2001 Mercedes ML270 /WDC1631131A450069 I have the following issue:erratic stop of engine,dashboard and turning on the lights.
No faults found on engine,only in dash-communication missing with the engine,cam,crank,injectors -all ok. Monitoring CAN I can see something strange-when the engine is shutoff CAN signal can't be decoded,something strange is captured.Before of engine shutoff I have a CAN command what turn off main relay,someone can help me to identify the sender of this message(ID 2-30)?
The .psdata is attached
https://mega.nz/#!5FAyHI7J!oSd5P4FspVUw ... l9jP1MmBw8
Thank you
Re: Mercedes ML engine erratic shutoff
Hi Victor, thanks for the post.
I cannot help with ID 2 30 but I am in the process of creating a forum post looking at CAN ID's and how to use a number of PicoScope hardware and software features to provide further information about "ID" origins within CAN.
Here is a link that will assist with CAN ID's
topic21680.html?
Take care.....Steve
victor2k
Post by victor2k »
Thank you for your support Steve.
Today I made a new capture with CAN H&L,+15 from ignition key and +15 from EAM module to ECU.Something wrong is happening in EAM module :shock: but until now I don't know what.
Best regards
victor2k
Post by victor2k »
Faulty EAM was the source of engine erratic shutoff. :?
Best regards
