Mokka 1.7 (LUD) starting issue
wade0059
Post by wade0059 »
I have a Vauxhall mokka 1.7 cdti (LUD) with an intermittent bad start when hot (it does fire but sounds rough and cuts out). I had a quick look the other night but annoyingly couldn't get the car to play up. All I'd like to know is if the crank sensor is pulling to ground clean enough in my capture? I appreciate it's pulling to ground in 38 microseconds so probably as clean as I'm going to get? but it keeps playing on my mind and just want somebody wiser than me to advise. I don't want to get too caught up on the crank sensor and move on
Vauxhall_Mokka_2013_cam_crank.psdata
(6.57 MiB) Downloaded 485 times
Re: Mokka 1.7 (LUD) starting issue
Post by Technician »
While your registered on here if you connect your scope at the same time you can access the waveform library and look up another MOKKA trace with your engine code, and then do a comparison.
wade0059
Post by wade0059 »
hi thanks for your reply, that was my original plan as I usually find the waveform library very useful but in this instance didn't have what I needed unfortunately
Ste81
Post by Ste81 »
Did you ever fix this problem mines doing exactly the same
Ste81
Post by Ste81 »
I got told this problem was my battery. So I changed it and it was perfect for 3 weeks then the hot start problem started again
