TA212 adapter
Cliff Roberts
TA212 adapter
Post by Cliff Roberts »
Is there an adapter for the ta212 to adapt the flare to standard pipe? I have some glowplug adapters that use a Parker quick coupler.
Re: TA212 adapter
Hi Cliff,
I think what you are after is this. https://www.picoauto.com/products/press ... ptor-kit-b
I believe the rectus fittings are what Parker use but there is more information on this page.
Let me know one way or the other.
Cliff Roberts
Re: TA212 adapter
Thanks for the reply and link. I don't think that is the correct coupler. From what I can tell, its a Parker ST series. I was able to build a 1/4" hose w/ 1/8" pipe fittings on both ends that I could then install the couplers needed.
Re: TA212 adapter
Hi Cliff,
Glad you managed to come up with a solution. Let me know how the results come out if you try out compression testing!
