possible to trigger on pintle opening or closing event ?
nurber
Post by nurber »
Hi Forum. Attached is a single waveform. Where the current and voltage waveforms intersect at the second injection event ( main injection ) you can see what I believe is the pintle closing for this injector ( just above where the blue current waveform intersects ). Is it possible to create a trigger on so small an event ? What kind of advanced trigger and with what arguments.
Thank you, Sven
Bessie trigger on pintle.psdata
(406.88 KiB) Downloaded 354 times
nurber
Re: possible to trigger on pintle opening or closing event ?
Post by nurber »
A runt pulse trigger seems to work quite well at least for the closing of pintle as evidenced in the voltage waveform. But can somebody point me to location of opening which I thought should be visible on current waveform ?
