missfire detection by crank sensor
autosparky
Post by autosparky » Fri Jan 20, 2006 10:15 am
think this might work? has anyone detected missfires by the time diferences between firing events? or on a crank angle sensor? in theory a dead cylinder should rotate the flywheel slightly slower due to lack of power stroke and slower again on the next compression.
ricardo
Post by ricardo » Fri Jan 20, 2006 2:35 pm
Yes in theory this is possible, this is how the PCM or ECU's OBD system detects misfire. The trick is how to process/analyse the signal captured by the scope.
Here is an interesting article you might find useful,
http://www.findarticles.com/p/articles/ ... i_n8891565
Another method used to detect misfire is analysis of the oxygen or lambda sensor. A company that specialises in this is Thomson Automotive Labs in the US. This is their website,
www.acemisfire.com
Best regards,
Ric
Ricardo Paloschi
Sales Engineer
Forum Moderator
anttdogg73
crank angle sensor
Post by anttdogg73 » Fri Feb 24, 2006 4:21 am
what is a crank angle sensor on a1.8l dohc acura integra engine its on a 96-01.
ricardo
Post by ricardo » Fri Feb 24, 2006 11:00 am
The crank angle sensor tells the ECU the position of the crankshaft so it can work out when to fire the plugs and injectors. Its usually either an inductive or hall effect sensor located on the flywheel or on a pulley at the other end of the crankshaft.
Best regards,
Ric
Ricardo Paloschi
Sales Engineer
Forum Moderator
