mini 2005 r52 1.6 denso charge system intermittent charge
sambowden1989
Post by sambowden1989 »
Hi I have got a mini in and I have fitted a two new alternators to the car but still no luck.
So I have looked up on auto data and according to that it is saying 2v/5ms idle but I am getting just under 12v/5ms when the alternator is charging properly from the ecu feed pin 52 white wire plug A
But when the alternator is not charging the ecu is switching 12v/5ms but with a random 30ms volt drop in the wave form :?
Has any one had any problems with mini smart charge systems.
Many thanks
sam
this is what I get when charging
this is what I get when its not charging
