PEUGEOT 207 2008 PETROL TIMING CHECK
JOE TECH
Post by JOE TECH » Mon Jul 30, 2018 8:54 pm
High got problem with peugeot 207 1.4 16 valve turbo year 2008 ( SAME AS MINI COOPER)
The engine is running rough hunting at idle Fault code set for lambda sensor too rich
Various tests carried out fuelling is ok above 1500 rpm
I Think there is a timing chain issue and have taken a timing check with my pico cam + crank
Can anybody post a good timing check of this engine to compare
Thanks Joe
Re: PEUGEOT 207 2008 PETROL TIMING CHECK
Post by liviu2004 » Tue Jul 31, 2018 9:59 am
Timing is usually bad also above 1500rpm. Look for air restriction.
