PicoScope 7 Automotive
Available for Windows, Mac, and Linux, the next evolution of our diagnostic scope software is now available.
Hi Technician, thanks for response. From my previous tutorials wached for no start i thought injector opens right befor spark is trigered and this is ms before peak cylinder pressure to give power stroke. The red curve is the spark just befor tdc and blue wpx cyl 1 pressure test, as expected but injector trigger confuses me as its after the power stroke nearly on exhaust opening if i understand correct? The vehicle does not even give sound of cylinder firing. All injectors does fire and all cylinders has spark but seemed to be not marching to ignite fuel. When using quick start no stumble start is experienced yence me thinking crank may be 180 deg out, as i understand crank controls injection and cam spark? What would.your ideal settings be for this testing?Technician wrote:Fuel injection event seems OK to me where it is, i.e. just before the inlet valves start to open.Kudugar wrote:HI
i have now rescoped with better settings. seems fuel injection trigger is way out vs cylinder pressure and spark on cyl 1 with wpx 500. it remains non start
I'd like to guess that the spark at the plugs is too weak to ignite the fuel given that the engine cranking speed is around 150 rpm!Kudugar wrote:Hi Technician, thanks for response. From my previous tutorials wached for no start i thought injector opens right befor spark is trigered and this is ms before peak cylinder pressure to give power stroke. The red curve is the spark just befor tdc and blue wpx cyl 1 pressure test, as expected but injector trigger confuses me as its after the power stroke nearly on exhaust opening if i understand correct? The vehicle does not even give sound of cylinder firing. All injectors does fire and all cylinders has spark but seemed to be not marching to ignite fuel. When using quick start no stumble start is experienced yence me thinking crank may be 180 deg out, as i understand crank controls injection and cam spark? What would.your ideal settings be for this testing?Technician wrote:Fuel injection event seems OK to me where it is, i.e. just before the inlet valves start to open.Kudugar wrote:HI
KimAndersen wrote:Hi Kudugar
I looked at your latest upload which seen with my knowledge looks fine and yet did I find something that maybe could be a problem. I´m here talking about the reference mark at the flywheel and the position of the missing two teeth which according to my information should be 60 degrees before top dead center (BTDC).
In your file the reference mark is at 70 degrees BTDC. What and if that has any influence on your engine I dont know, but it seems a bit odd to me.
I have just realised that the injwction of cyl 1 is actaully happening on the exhaust stroke although the waste spark is happening just before tdc combustion stroke as expected. Form my understanding the injection cycle should by in the inlet stroke before compression stroke. In thus i seem to be of the understanding that the crank may need to be rotated by 180 deg to correct as crank sensor determine the fueling strategy. Your comments will be highly appreciated.
Kim
Please see attachments specspeck wrote:Hi Kudugar, technician has already pointed out the injection is okay. usually injection takes place at the exhaust stroke.
Your understand where the injection takes place is not right. Hope that helps.
