Chevrolet Spark - Compression waveform - help!
sid
Post by sid »
Hello
Here I have a Chevrolet Spark 2010 1.0l 16v. Starts and runs but lacks power with a slight misfire (incomplete combustion) at idle. Suspected valve timing. Timing marks are coloured chain links and only one mark on the crank gear. Old chain had stretched by one link. New chain fitted. Waveform captured is with inlet choked. Without choke vacuum pocket on exhaust stroke was -2.5bar! What are your thought?
Chevrolet Spark - Petrol 995cc 16v - Bad.New chain.psdata
(1.45 MiB) Downloaded 506 times
Re: Chevrolet Spark - Compression waveform - help!
Post by Autonerdz »
Since that pressure does not exist, you have an instrumentation issue.
Start by selecting DC coupling not AC.
sid
Post by sid »
School boy error! Must have changed it accidently.
Lesson learned, always check your scope settings.
Thank you :D
