VW Fuel Metering Valve voltage
Brad H
Post by Brad H »
Hi all,
I have a VW Amarok in my shop for a no-start. The customer sent the ECU away at some stage for a tune & the tuner sent the wrong ECU back.
When they plugged it in it blew the 'fuel pump' fuse. They finally realised it was the wrong ECU & had the correct one sent to them.
After this it wouldn't start. The did notice the Fuel Metering Valve (FMV) was getting hot.
They replaced it , still couldn't start it so had it towed to me.
After checking all circuits I found the fuel system was failing to make rail pressure.
It would randomly hit correct pressure & start after about 10-15 seconds of cranking, with the engine idling the FMV was seeing a peak voltage of around 18 volts.
KOEO this circuit was seeing 17 volts ,then, KOEO it rose to almost 19 volts.
My personal vehicle is a 2015 Amarok with a CSHA engine & I checked the same circuit and saw 14.7 volts at idle & 12.8 volts KOEO.
Anyone seen this problem before?
2012 VW Amarok 2.0 litre bi-turbo diesel
Engine code: CDCA
My FMV.psdata
(444.54 KiB) Downloaded 550 times
KOEO then key off.psdata
(616.61 KiB) Downloaded 531 times
ronw38
Re: VW Fuel Metering Valve voltage
Post by ronw38 »
Hi Brad H KOEO if the voltage across the battery is normal , the high voltage at the FMV may be due to some form of bleed off or voltage leak from the injector capacitor circuit ? as the ECU has been modified I would be conferring with the tuner. Also check ECU voltage inputs are normal. You are fortunate to have your vehicle as a comparison . cheers Ron
