Parasitic drain
Robbo135
Parasitic drain
Post by Robbo135 »
Hi Guys,
I have a bmw 323 E90 and customer complaining of a repeated flat battery, have checked battery, charge rate and carried out a parasitic drain test. I'm showing a current draw of 250mA when vehicle has finally gone to sleep (this has taken approximately 30 mins). My question is what is an acceptable drain? Any help appreciated.
Re: Parasitic drain
Post by liviu2004 »
250 mA is too much. There are several methods to determine the faulty circuit, you can try fuses voltage drop test and why not, thermal imaging camera.
victor2k
Re: Parasitic drain
Post by victor2k »
Some faults in engine control module(like smart sensor,alternator,aux water pump-all share the same bus of data)?
I think a current consistently over 50 mA must be investigated.
Best regards
Robbo135
Re: Parasitic drain
Post by Robbo135 »
Thanks Guys. Unfortunately I don`t have a thermol imaging camera but that is a flash suggestion. I -believe that I am down to the fuse pulling or volt drop testing methods for the time being! I will be testing with the 50mA and less in mind.
Thanks again
Zap
Re: Parasitic drain
Post by Zap »
So, I don't know about BMW's specifically, but I know that Fords made in the same time period needed to be at rest for at least 40 minutes before going to sleep. I also remember reading TSBs from other german automakers (maybe Audi?) that say to let the vehicle sit for at least 2 hours before doing a drain test.
What's the drain after 2 hours?
