Picoscope command prompt command not working.
sandesh.achari
Post by sandesh.achari » Mon May 07, 2018 12:19 pm
Hi, I am using Picoscope 6 Automotive version 6.12.7.2724. I am trying to convert the psdata file into a different format using the command prompt. However, it goes in an unhandled exception and stops working. Following is the error. How to solve this? Is this a bug in picoscope software? The same command was working in the previous version.
picoscope /c s2_inj6.psdata /f mat
Unhandled Exception: Pico.MVVM.IoC.IoCRegistrationException: Pico.MVVM.DialogService.IDialogService:Type Pico.MVVM.DialogService.IDialogService not registered
at Pico.MVVM.IoC.PicoIoC.Resolve(Type T, String name)
at Pico.MVVM.IoC.PicoIoC.Resolve[T](String name)
at i..ctor(lJ gui, mq recentFilesMenu, bV deviceDialogControl, ey powerSourceDialog, ez progressService, lE fileDialogsCreator)
at l.a()
at oo.Execute()
at n.a(String[] , Boolean )
at PicoScope.PicoApp.<>c__DisplayClass0_0.a()
at d.a(List`1 )
at PicoScope.PicoApp.AppMain(String[] args, Boolean consoleMode)
at Pico.PicoScope.PicoScopeCmdLine.Main(String[] args)
Re: Picoscope command prompt command not working.
Post by ben.martins » Fri May 11, 2018 8:27 am
Hello Sandesh,
Thank you for your post. I think the best option here is to email into support@picotech.com. If you provide them with as much information as possible about the problem you are seeing, I'm sure they will be able to assist.
