J2534 device for NVH
automotivemd
Post by automotivemd » Mon Apr 23, 2018 9:42 pm
Does anyone have a recommendation for a pass thru device for the NVH to read RPM Speed etc? I originally was able to use my Escan pro, but that has stopped, I tried my Bosch VCI, Flasher pro and my OTC MVCI with nothing working. Any ideas?
Re: J2534 device for NVH
Post by Steve Smith » Tue Apr 24, 2018 6:03 am
Assuming the devices you mentioned are Pass Thru devices (via the J2534 Protocol) they should function with our NVH software.They will however require the relevant Driver to function as a Pass Thru device
I know with a number of Bosch users with Pass Thru devices a firmware update was required accompanied with a "Check Box" requirement to "Enable Pass Thru" within the relevant software. This would also be Hardware specific and I refer to the KTS 590
The device we recommend is from our friends at Drew Technologies and the lead is their MongoosePro ISO/CAN2
https://www.picoauto.com/download/docum ... /MM091.pdf
The lead can be purchase via your Pico Distributor or direct from Pico if this helps?
Take care.......Steve
automotivemd
Post by automotivemd » Mon Apr 30, 2018 4:23 pm
Thanks Steve, I purchased the Mongoose and still cannot connect too 2 vehicles, a 03 7.3 diesel Excursion and a 99 lincoln town car, but it seems to connect to newer vehicles quickly. Any ideas?
victor2k
Post by victor2k » Tue May 01, 2018 3:56 pm
automotivemd wrote:Thanks Steve, I purchased the Mongoose and still cannot connect too 2 vehicles, a 03 7.3 diesel Excursion and a 99 lincoln town car, but it seems to connect to newer vehicles quickly. Any ideas?
On diesel cars from 1996 to 2003 OBD II not offer a complete coverage,also your purchased Mongoose ISO/CAN 2 can support only ISO,KWP and CAN protocols ,not J1850 VPW and PWM protocols(for this you will need Ford or JLR Mongoose) .
I think a ELM327 clone or a Bosch KTS with passthru firmware will work better.
Best regards
automotivemd
Post by automotivemd » Tue May 01, 2018 8:49 pm
Wow, Victor, great info thank you. I'll get busy with this advice thanks again.
