A slight miss
Jesper
A slight miss
Post by Jesper »
I have a car with waste spark system. the firing kv for cyl 3+4 is much higher than for cyl 1+2. Also the burn voltage on cyl 3+4 is sometimes very high and drops slowly back towards bat. voltage. What causes this ?? I have a slight mis I think. cables and plugs are new. Engine have been overhauled, but not new lifters.
cyl 3 lot of load on battery.psdata
blue cyl 3 and red cyl 1. notice the diff in fireing kv
(2.68 MiB) Downloaded 496 times
Re: A slight miss
Post by Autonerdz »
You cannot reliably capture the firing KV with that low of a sample rate. You must have a one microsecond sample interval. Yours is 3.34.
That is an unfortunate characteristic of the secondary probes. It has nothing to do with the vehicle and can be ignored.
Jesper
Re: A slight miss
Post by Jesper »
Thanks. I am still learning, so thanks for the reply.
Compared with cyl 1, something is different... :D
