Ford Smart Charging Systems
Dcunning35
Re: Ford Smart Charging Systems
Post by Dcunning35 » Tue Feb 27, 2018 6:34 pm
Tech all you need to do is check the negative battery terminal for presence of a bms sensor this will verify if the vehicle runs normal smart charge or smart regenerative charging.
The up to 15.1v is for deep cycling only when the soc is lower than a predetermined level all this management of battery health is done between the bms and the bcm.
The bcm.tell the pcm how to drive the generator.
If the battery or generator control uniwithin the alternator are not oe I can see you having charging issues.
The bms reset is a manual reset and doesn't need ids , etis ids or fdrs to be utilized.
If I had more vehicle information id help gladly but without it we are repeating ourselves
Best of luck
Post by Technician » Tue Feb 27, 2018 6:57 pm
Danny I'll sort the VIN number out for you tomorrow. Thanks for your help. :)
Post by Technician » Wed Feb 28, 2018 11:46 am
Dcunning35 wrote:If I had more vehicle information id help gladly but without it we are repeating ourselves
Best of luck
Danny please check your PM system thanks
