WPS500X - TA086 Bleed hose question
VASTech
Post by VASTech » Thu Feb 08, 2018 9:20 am
Hello!
Anyone know what size of brass nut has TA086 bleed hose adapter?
Thank you!
PhilS
Re: WPS500X - TA086 Bleed hose question
Post by PhilS » Thu Feb 08, 2018 5:53 pm
Hi dorcky
It is a half inch (approx 12.7mm) connector.
I hope that is the information you needed.
Best regards,
Phil
VASTech
Post by VASTech » Thu Feb 08, 2018 7:02 pm
Not quite sure if is a half inch. I measured on wp500 bleed male, and I've got ~11mm. But I'm quite sure that is not metric is most likely imperial. Friend Google say a match of 7/16" at ~11mm but I don't know... Keep looking.
Thank you!
PhilS
Post by PhilS » Fri Feb 09, 2018 7:49 am
Hi dorcky
If you are talking about the outside flat-to-flat on the brass nut then it is half inch.
I can be sure about my sample from stock as I measured it last night and this morning.
Let me know if you were after something different as I may not have been measuring what you wanted.
Best regards,
Phil
TA086 nut
VASTech
Post by VASTech » Fri Feb 09, 2018 8:47 am
I need inside diameter. Sorry for misleading!
VASTech
Post by VASTech » Fri Feb 09, 2018 2:57 pm
I need a type of that nut, to be able to buy one. I think is a 7/16 thread.
Question is :
it is a 7/16-14 UNC or 7/16-20 UNF thread.
Regards!
PhilS
Post by PhilS » Fri Feb 09, 2018 3:13 pm
Hi dorcky
Sorry for being so dim.
The brass nut is 1/8” FPT, designed to mate with the brass 1/8” MIP bleed port fitting.
I hope I have given you the information you needed.
Best regards
Phil
VASTech
Post by VASTech » Thu Mar 15, 2018 6:40 pm
Well, not find so far what type of nut is that one. Nothing seems to match. 1/8" BSPP male is only 8.7 mm inside. 1/4" BSPP male is 11.6 mm inside. FOSTER 2202 Quickplug and 22-2 adapter is (1/8" NPT) - 10 mm - not match with what I need.
The bleed brass adapter screwed in WPX is 10mm inside (1/8" MPT) and 11 mm outside and don`t know what type is.
PhilS
Post by PhilS » Tue Mar 20, 2018 5:39 pm
Hi dorcky
Really sorry for the delay as I have been travelling.
Please always feel free to email support@picotech.com for anything requiring an answer.
Anyway, the details are:
The Thread size for the ¼” OD compression is 7/16" X 24
The brass fitting is a part of the Watts A-22 (LFA-22) Compression fittings, complete with an “Ander-Lign” tube to male pipe connector with brass insert. The O.D. threaded piece is 1⁄4" OD Comp. X 1⁄8" MIP
Best regards,
Phil
