CDI Ignition waveforms for Motorcycle
BrianL
Post by BrianL »
I noticed in the guided tests that there are specific motorcycle tests and waveforms. Not sure why an ignition system that is identical to any automotive ignition was shown? Some waveforms from a CDI system would be much more useful since they aren't used anywhere except on motorcycles. Does anyone have some good primary and secondary waveforms from a motorcycle CDI?
Re: CDI Ignition waveforms for Motorcycle
Hello Brian, thank you for the post.
You are correct and I apologise in advance as we should have a Guided Test to incorporate CDI
This is on our list and we will get to it rest assured.
The Waveform Library has a number of examples of Motorcycle ignition systems (inc. CDI) which is also utilised on lawn mower and marine engines.
I have found the following secondary waveform below from a Suzuki DF25A that I hope will help?
Suzuki_DF 25A_2015_Petrol_20180124-0002.psdata
Suzuki CDI Igntion
(82.71 KiB) Downloaded 758 times
Take care.......Steve
