2007 Dodge Caravan/Chrysler Town and Country 3.8L with a misfire. In this video I will walk you through some simple tests to help you isolate the cause.
Scanner Danner - misfire quick tests
Found a useful article or video on the web? Post links that will help other PicoScope users here.
1 post
• Page 1 of 1
Jump to
- Introductions
- Automotive kit hardware
- ↳ Charging Circuits
- ↳ Current/Volts Idling (12V)
- ↳ Current/Volts Idling (24V)
- ↳ Alternator AC Ripple/Diode Test
- ↳ Ford Focus Smart Alternator
- ↳ Petrol
- ↳ Diesel
- ↳ 1 Wheel
- ↳ 2 Wheels
- ↳ 4 Wheels
- ↳ Digital
- ↳ Analogue/Analogue
- ↳ Analogue/Digital
- ↳ Air Vane
- ↳ Digital
- ↳ Hot Wire [Petrol]
- ↳ Hot Wire [Turbo Diesel]
- ↳ Boost Pressure Sensor
- ↳ Hall Effect
- ↳ Inductive
- ↳ AC Excited
- ↳ 5V
- ↳ Vauxhall Simtec
- ↳ Hall Effect
- ↳ Engine Cranking
- ↳ Engine Running
- ↳ Hall Effect
- ↳ Engine Cranking
- ↳ Engine Running
- ↳ Common Rail Diesel
- ↳ Knock
- ↳ Titania
- ↳ Zirconia
- ↳ Zirconia with Heater
- ↳ Zirconia Pre & Post Cat
- ↳ Analogue (Petrol)
- ↳ Analogue (Turbo Diesel)
- ↳ Digital
- ↳ Throttle Potentiometer
- ↳ Throttle Switch
- ↳ Hall Effect
- PicoScope 6 Automotive software
- PicoDiagnostics software
- PicoDiagnostics NVH
- Diagnostic discussion
- Case studies
- Help me fix my car
- Best of the web
- Forum feedback
- ↳ News
