afm help
hijakd
afm help
Post by hijakd » Wed Dec 27, 2017 8:06 am
hey guys iv tested a fair few analogue airflow meters,recently i did a honda accord with a k24a engine and i found on a snap throttle it would hit the factory cut out at low rpm so i cannot get an accurate wave form of the afm pls enlighten me on how you guys do it
Re: afm help
Post by Steve Smith » Tue Jan 02, 2018 10:29 am
Can I confirm by the factory cut out you refer to RPM limitation due to PCM control?
To clarify, this is a PCM feature to prevent max RPM at zero road speeds.
If so (and if the PCM will allow) there may be an over-ride feature where RPM limitation can be disabled with a Scan Tool
If not (and I have never seen such a feature) a road test has to be remaining option which will incorporate load.
Here then a WOT road test monitoring the analogue AFM output (for max output and rise time) with PicoScope in conjunction with the Scan Tool for the measured Air Flow Quantity (e.g gm/sec) will provide the necessary information you require to confirm the integrity of the AFM
Be aware of existing faults that could influence peak airflow (restricted intake/exhaust)
Re: afm help
Post by Autonerdz » Tue Jan 02, 2018 4:19 pm
If the vehicle had a manual throttle, the MAF will peak on the intake fill on initial full throttle plate opening. No need to hold it and raise the RPM to cut out.
If the vehicle had electronic throttle control, then you cannot peak the MAF in this manner because you cannot snap the plate open. These require a dyno or road test to achieve max air flow.
