compression waveform help
rburgy
Post by rburgy » Thu Nov 23, 2017 2:01 am
I have a 2002 Ford Escape 3.0L engine. have a dead misfire on number 2 cylinder. found broken exhaust valve springs
on number 2 cylinder. replaced #2 exhaust valve springs. number 2 still misses constantly. checked for spark and fuel with no issues there. If i was out of time, at least the whole rear bank would miss. performed a relative compression test and found one cylinder with no compression.
next i performed an in cylinder cranking compression test on #2 and it showed 180psi??
lastly i performed an in cylinder running compression test on #2 cylinder and it looks like i found the issue. appears to be a burnt exhaust valve?
does anyone disagree with this diagnosis?
why would a cranking compression show good but relative compression clearly show an issue?
please let me know any thoughts.
thank you
ford escape cylinder 2 compression.psdata
(190.06 KiB) Downloaded 166 times
escape 3.0 cylinder 2 running compression bad.psdata
cranking relative compression
(7.76 MiB) Downloaded 136 times
ford escape relative compression bad.psdata
running compression using wpx5000
(2.97 MiB) Downloaded 131 times
victor2k
Re: compression waveform help
Post by victor2k » Thu Nov 23, 2017 8:08 pm
Please look at the moment of opening of exhaust valve:look how fast the cylinder pressure decrease/compared to the cylinder pressure increase.Try to record also the pressure in intake or exhaust.Sometimes only the compression will not show the issues... :?
Ford_Escape_2002_Petrol_20171123-0002.psdata
(82.32 KiB) Downloaded 127 times
rburgy
Post by rburgy » Sat Nov 25, 2017 1:00 am
victor2k wrote:Hello,
just to clarify, are you saying to use wpx500 and measure exhaust pulses, and use it to measure intake manifold pulses as well?
if the exhaust valve is burnt, it would affect both waveforms. correct?
thank you
Post by Technician » Sat Nov 25, 2017 6:11 pm
Victor2k might be asking you to record inlet manifold vacuum pressure?
victor2k
Post by victor2k » Sun Nov 26, 2017 7:21 am
rburgy wrote: if the exhaust valve is burnt, it would affect both waveforms. correct?
thank you
Sometimes you can't see a burned valve/wrong free play of valves only measuring the compression...
Adding a new measurement of intake/exhaust pressure to the cylinder pressure you will see where is the problem,or you can perform a leak down test . :)
