set up help
jfree
set up help
Post by jfree »
not sure if this is in the right place ,but i have an old automotive 212 scope and have hardly used it .
any way i have an laptop and the software set up on it and have started to use it to profile diesel injector reaction to time on a test bench ,trying to looking at the correction code of an injector , can some one please help me ?
i am trying to find out how to calculate the cycle deviation of an injector if i set the pressure and injector pulse width to a set figure
i have set the scope using the automotive actuator set up for diesel injector and attached a capture of one injector .is there a way to get the program to display the injection cycle deviation ?
Re: set up help
Hi jfree,
Welcome to the forum. A 212 scope! Don't know is that a Pico!! If not you may struggle to get help unless somebody actually knows the scope you require help with.
Ideally, you should post in the diagnostic discussion section of the forum. :)
Liteace
Re: set up help
Post by Liteace »
ADC212 is old picoscope
https://goo.gl/images/aE8qnY
Re: set up help
The scope is fine, it is a heritage version but a Pico all the same. No issues there !
Please elaborate on this, What are you looking to fix or achieve ??
jfree
Re: set up help
Post by jfree »
yep old scope ,i had it for years ,never used it ,but still works for my needs
