Recognition of Picoscope 4425 fails in Windows 7
asim
Post by asim » Fri Sep 29, 2017 10:32 pm
I am using the Picoscope 4425 with the Picoscope 6 Automotive software version: 6.12.7.2724.
Normally I am using a virtual machine but since I couldn't get the Picoscope recognized anymorewithin my virtual machine I grabbed my windows 7 pro 64 bit laptop and installed Picoscope 6 Automotive on the laptop.
Despite the fact that my laptop is a "pure" windows laptop I also didn't managed to get the picoscope up and running.
What happens is the following:
[1] I start up windows
[2] I plug the Picoscope 4425 in the usb-port
[3] The picoscope gets recognized properly by windows. As you can see it shows up in the device manager:
[4] As soon as I start the Picoscope 6 Automotive software I hear the unloading of a USB device while almost on the same time the software says that no suitable device is found:
[5] When I check the device manager after [4] the Picoscope doesn't show up in the device manager list:
So for some reason the "recognized" Picoscope gets unloaded as soon as the Pico automotive software is loaded resulting in the software not finding a suitable instrument.
Do you know how I can resolve this issue.
What I did so far:
-> reinstalled the software with the repair option
-> rebooted my windows pc several times
-> performed all the above as a "Windows"-administrator
Best regards,
Asim
Re: Recognition of Picoscope 4425 fails in Windows 7
Post by Martyn » Sat Sep 30, 2017 6:11 am
Sounds like there isn't enough power being supplied to the unit, from the USB port.
Are you still using the blue USB cable supplied with the unit ?
Check the USB ports, and cable for signs of damage.
Post by Technician » Sat Sep 30, 2017 12:47 pm
Asim,
It's got to be something and nothing causing your problem, I'm using Windows 7 Pro and 64 bit like you and the scope runs OK on my computer using Pico software automotive as you listed.
Post by Autonerdz » Sat Sep 30, 2017 2:25 pm
We had never seen anything like that before last week. Have a customer with this exact scenario now. But in this case, only the USB 3.0 port is affected. His 2.0 ports are working just fine. This is an Acer Win 7 pro 64 with good resources.
My first thought was what Martyn mentioned that there is a lack of sufficient USB power. The customer was not wanting to spend more time chasing this but if we had something else to go on I could probably talk him into it.
Just curious if other USB ports have been tried.
Anyway... Following with interest....
Post by Technician » Sat Sep 30, 2017 4:05 pm
Asim,
You could put a booster on your USB port to see if that helps.
Post by liviu2004 » Sat Sep 30, 2017 10:49 pm
Asim, if you are fron NL or BE, why don’t you come along, we can try swap laptops and scope and do some research what works where. I have the same scope, win 7 x64, vista x32.
mikeleb33
Post by mikeleb33 » Sun Jan 21, 2018 11:53 pm
I just received a brand new 4425, installed software on a work supplied laptop and successfully connected scope hardware. However I am unable to connect to my personal laptop running windows 7 64 bit. Im having the same issues as asim, my laptop sees the scope connected via multiple USB ports but as soon as the software runs, is looses connection and all I get is DEMO mode. I have reinstalled software multiple times and experience the same issues. Ive tried running STABLE and BETA versions with no improvement. Any update on this issue? I can get by with the computer from my work but my personal would be preferred as it is way more powerful and I can bring home with me.
Post by liviu2004 » Mon Jan 22, 2018 8:51 pm
Maybe not relevant, which software are you running? Other devices on the usb ports in the same time?
Is scope showing ok on Device Manager? Some print screens?
mikeleb33
Post by mikeleb33 » Thu Jan 25, 2018 2:45 am
Compared USB voltages and found my DELL Latitude E6440 had slightly lower out put (4.9-5.1V) than the HP I use at the shop (5.2-5.4V). I tried a USB booster cable but still not able to connect the scope. Both laptops are running latest versions of windows 7 pro service pack 1. When the scope is connected the computer makes the "ding-dong" sound and the drivers are verified, as soon as the Pico software is launched you hear the "dong-ding" as if the USB is disconnected and the software defaults to demo mode. The "connect device" menu refreshes automatically when connecting the USB but it never "finds" the scope and again defaults to demo. Same result with version 6.12.7 and 6.13.1
Post by Steve Smith » Thu Jan 25, 2018 1:23 pm
Hello and thank you for your feedback and so sorry this is not resolved.
Could I ask if you have access to a double headed USB 2.0 lead
I ask this because it does sound like current limitation to the Pico Device via USB 3.0 sockets/laptop
At the point of connection to your scope (Handshake) load is applied to the USB port until the handshake is complete, where by current consumption is reduced dramatically
A double headed USB 2.0 cable will move the diagnosis along by one head of the USB cable providing power and data exchange, whilst the other provides additional power only
Moving on, could we check for any environmental/current limiting settings specific to your laptop device?
Finally can we obtain a trace file from the Pico Technology folder.
This will involve connecting your scope as normal, waiting for the failure to connect, then closing the software.
Upon closure a trace file will be written to the PC, could you send this over tosupport@picotech.com
TRACE FILE LOCATION INC WINDOWS 10.pdf
How to locate the trace file
(161.21 KiB) Downloaded 139 times
Once again, I appologise sincerley for this concern
Take care......Steve
