Compression K9K-702 1.5DCI
Tronic
Post by Tronic »
Hi!
Back after a long period of illness and finally, at least with 50% strength, back att work. We have a 2004 Renault Kangoo with a K9K-702 engine and a non start condition. A relative compression test revealed the following mixed compote: 19, 18, 15 and 20 Bar. My question: what are the compression specifications for this particular engine?
Thanks in advance!
Re: Compression K9K-702 1.5DCI
Hi Tronic,
The technical data I have advises a compression ratio of 18.3.1, this equates to approx 18 bar.
Tronic
Post by Tronic »
Hi Technician and thanks for reply!
Now I will continue, compression test was just a start. This car have a more or less unknown background, so not much help from there.
Thanks again Technician! :D
volrem
Post by volrem »
Technician wrote:Hi Tronic,
I disagree. Compression pressure should be higher than compression ratio.
It also depends of additional volume measuring tool has.
With WPS I usually measure measure 22-23 bar (18:1 engine) and with compensation it's 27-29 bar.
post64371.html#p64371
The compression ratio I thought was the minimum acceptable and not the maximum, so yes I agree it should or would be higher when tested dynamically, especially with a warm engine, but as a guide it should be reliable.
I just located a formula which includes specific heat ratio, therefore;
pTDC = 1 bar x 10.3^1.4 = 26.2
The end result I suspect would very much depends on manufacturer cam and valve timing specifications, volumetric efficiency, and what they have calculated as their specific heat ratio.
Mark Dalton
Post by Mark Dalton »
That looks like a formula from a wikipedia page "https://en.wikipedia.org/wiki/Compression_ratio" where the 10.3 is the compression ratio, so I think your specific formula should be (1 bar * (18.3^1.4)).
Sorry typo error on my behalf
