Hysteresis and window pulse width
Hi all. I recently was trying to trigger off of a hall effect crank sensor which had the usual missing tooth on the pick up. In the end I did manage it (more luck than judgment) I was wondering if someone could put into layman's terms what the hysteresis and voltage window settings mean in the setup menu. As the trigger wasnt very stable, and I didnt really have a clue what I was doing.Thanks very much for your time and help.
- TwoWaves
Re: Hysteresis and window pulse width
I never noticed the post RYM
I assume the information is from a Pico online manual, do you know of an updated version?
https://www.picotech.com/library/oscill ... l-triggers
I always find the Runt Trigger amusing....!
Here is the PicoScope 6 User Guide
The content is available directly in the software either from Help->User'sGuide , or clicking the Help button in the Advanced Trigger menu
