Cam/Cranck Chevrolet Aveo F14D4
Melissen71
Post by Melissen71 » Sun Sep 10, 2017 12:12 pm
Who has a good cam/crank signal for a Chevrolet Aveo 1.4 2011 F14D4 engine?
I'm not sure if the timing is wrong or that there's an other problem.
I've got several screendumps from ther problemcar. Also with actuators for camshaft valve timing disconnected.
Because of the P0341 the intake camshaft will not advance or retard
Hope you can help me.
Best regards,
Hein Melissen
the Netherlands
Camshafts CVVT disconnected
Melissen71
Re: Cam/Cranck Chevrolet Aveo F14D4
Post by Melissen71 » Wed Sep 27, 2017 3:28 pm
Problem solved. both camshafts have 2 large and 2 small pulses.... You can see that one camshaft has only 1 short pulse. Reason: broken camshaft rotor.
