Alfa Romeo MITO P1062
RYM6746
Re: Alfa Romeo MITO P1062
Post by RYM6746 » Mon Aug 21, 2017 8:52 am
Managed to get voltage today not sure its going to help much. car was misfiring slightly in the capture. Channel B and C are still the current waveforms sorry forgot to change scale again. Channel A is the voltage of the suspect solenoid and channel D is the voltage of the good solenoid
Looking at it more closely I think I would have to use all 4 channels on voltage as it is clearly controlling the current flow by adjusting the voltage on both wires. Maybe this is how it is accurately producing the fault code. and it is running some sort of diagnostic strategy on every other turn on event??
Alfa Romeo_Mito_2013_VVL solenoid voltage and current GOOD and BAD.psdata
(9.32 MiB) Downloaded 100 times
Martinjensen
Post by Martinjensen » Mon Aug 21, 2017 10:50 am
Hi RYM.
A function description for the multiair system, can be found on Alfa E-Learn.
I think the ECU is looking at the missing V-shape of the current profile, and flags the P1062 Code
2017-08-21 12_57_29-PicoScope 6 Automotive - [Alfa Romeo_Mito_2013_VVL solenoid voltage and current .png
RYM6746
Post by RYM6746 » Mon Aug 21, 2017 6:19 pm
Brilliant information thanks very much. Exactly what I needed to confirm solenoid failure. Where did you source this from?
On the down side we are struggling to get the locking tool so we may not be able to see the job through to the end :(
Post by STC » Mon Aug 21, 2017 9:24 pm
Rym
That may not be such a bad thing - hold that thought.
Persuade your customer to let you supervise it in and out of the dealer for an admin fee. Present it to the dealer with your findings, scope traces, PDF from Martin, Print out of this thread if you wish...
You may find it impossible to find a dealer that will take that on, if you do then you have your customer covered every which way.
Technicians like you are thin on the ground and your customer may not find another in a lifetime !!!
You have diagnosed it - That is your job done !!
How many of your competitors in a 100 / 1000 mile radius can mimic that ???
Well done from me, you stuck to your guns and fought your corner with Passion, fact and Conviction :) :)
Martinjensen
Post by Martinjensen » Wed Aug 23, 2017 6:17 am
you're welcome.
The information can be found at: https://www.technicalinformation.fiat.com
Descriptions > 10 ENGINE > 1036 TIMING > INTRODUCTION - TIMING SYSTEM
RYM6746
Post by RYM6746 » Wed Aug 23, 2017 9:30 pm
Thanks again every one for all your help and advice
Post by STC » Thu Aug 24, 2017 9:44 pm
RYM6746 wrote:Thanks again every one for all your help and advice
I learnt a great deal here too - So thanks to all contributors :)
