where can i set Proxy for waveform Libery?
maximili
Post by maximili »
if i try to start the waveform libery from:
PicoScope® 6 - PC-Oszilloskop-Software Version: 6.12.7.2724
Copyright © 1995-2017, Pico Technology Ltd.
Modell: PicoScope 4425
Seriennummer: DV047/0281
USB-Version: 3,0
Kalibrierungsdatum: Mittwoch, 18. Mai 2016
Hardwareversion: 1
Treiberversion: 1.3.0.16
Firmwareversion: 1.4.0.0 / 1.0.25.0
i get the following Warning:
'Proxy Authentication Required'
as dokumented in the ateeachement.
can you help, where do i have to Setup the Proxy adress?
greetings Max
Re: where can i set Proxy for waveform Libery?
Post by Martyn »
This is not an error message I have seen before with the Waveform Library, and the people I would need to discuss this with are not in the office until Monday.
What type of internet network are you connected to ?
Is your PC setup to use a Proxy ?
