2013 Ford focus will not perform DPF regeneration
johnyor
Re: 2013 Ford focus will not perform DPF regeneration
Post by johnyor » Thu Sep 21, 2017 6:46 pm
Hi, have you figured out what was going on ?
Liteace
Post by Liteace » Thu Sep 21, 2017 10:40 pm
johnyor wrote:Hi, have you figured out what was going on ?
I hope so, last post was 5 months ago
RYM6746
Post by RYM6746 » Sat Sep 23, 2017 10:37 pm
Yes vaporiser in exhaust was blocked with soot. New vaporiser fitted and all was good
Post by STC » Tue Sep 26, 2017 8:47 pm
What is the fuel level in the tank ???
rfedyk
Post by rfedyk » Sun Jan 13, 2019 1:44 pm
Hi Guys,
Need to refresh this topic. I have a focus econetic 1.6 tdci 63 plate and have a similar problem, dpf regent temp will not go above 550deg.
Checked:
-Glow plug on vaporiser- .7 ohm
-flow through on pipes from vaporiser pump to end of vaporiser -all clear
- power going to glow plug while regent is happening- all ok
- relay is engaging, all good,
-pump is working, fuel going into the vaporiser,
- both temp sensors.
I'm getting .48kpa on pressure difference sensor and builds up to 2.5kpa while running 2500rpm
Could any of you tell me what should I check?
Could it be not enough oxygen?
Now I got a mil with soot accumulated-filter restriction.
Any ideas welcome :)
Thanks!
