Focus intermittant no start CAN BUS
Re: Focus intermittant no start CAN BUS
Post by STC » Sat Apr 08, 2017 9:23 pm
Some great information being shared by pico users
We are agreed on the Hi Speed (critical) CAN :)
The Body or Convenience (non critical) CAN on VAG I have always known to be 2 twisted wires and Mirror image however it will run in single wire mode if one side is damaged and give a fault code.
VAG do extensively use K line & LIN too which are single wire. Add to that MOST Fibre Optic, Wireless, Infra Red, Bluetooth, Wireless, Radar .... ..... ..... Just because our job is not hard enough I guess.
So, for example, a 2013 VW Golf worth a few £k has more Networks for it to function correctly than whole Countries or Continents. Puncture two of its (if not runflat) tyres and it is ruined, a brick, absolutely useless !!!
It has to be a conspiracy :D :D :D to get rid of us Technicians, Diesels (Money Makers) are slowly going, Petrols are in the minority and can always be fixed with a Coil Pack, Hybrids and Full Electrics don't go Wrong.
The end of the diagnostic technicians world is how far away ??? :D :D :D :D
RYM6746
Post by RYM6746 » Sun Oct 01, 2017 9:13 am
If anyone has the symptoms I have described in this thread. Here is the fix.
https://youtu.be/9iTi_ZeRujM
I have seen this fault numerous times and usually a good whack on top of the cluster will get the car started/diagnosed and into the work shop ready for repair
