New Stable Release 6.12.7 Available to Download
PicoKev
Post by PicoKev » Sat Mar 18, 2017 12:21 pm
Hi Guys & Gals,
In case you have missed it there is a new stable release available.
Here: https://www.picoauto.com/downloads
:D Amongst other things you will find it contains: :D
PicoScope 6 Automotive 6.12.7
Release notes
New Features PicoScope6 Automotive:
* Serial Decoding UI improvements
* Serial Decoding - Packet Fields integration
* Serial Decoding Table performance improvements
* Added CAN FD Serial Decoder
* Added pop-up notifications
* Redesigned channel overrange warning
* Improved handling of mismatched PicoScope .psdata files
New Features PicoDiagnostics:
* Google Analytics integration
* NVH
- Filters improvements
- Up to 64 harmonic markers can be added
- Microphone playback now combines all channels in view into a single audio channel
- OBD PID data can be logged in parallel with vibration data
tas_daz
Re: New Stable Release 6.12.7 Available to Download
Post by tas_daz » Tue Mar 21, 2017 6:19 pm
i can work this version in windows xp?because i see is for win 7 and up.thanks
volrem
Post by volrem » Tue Mar 21, 2017 6:58 pm
tas_daz wrote:i can work this version in windows xp?because i see is for win 7 and up.thanks
No support for Windows XP for a while now.
Look here:
post45511.html?hilit=windows%20xp#p45511
PicoKev
Post by PicoKev » Tue Mar 21, 2017 7:47 pm
tas_daz
If you do not have picoscope software and you only have XP, go to https://www.picoauto.com/tech-support and click on Technical Support; fill in a support ticket and ask for a link to the last version of picoscope that you can use I am sure the guys will be able to help, but unfortunately since Release 6.12.1 the software will no longer work with XP.
Sadly time and software marches on.
Hope that helps.
Kev.
tas_daz
Post by tas_daz » Tue Mar 21, 2017 8:55 pm
thanks my friend
Post by Martyn » Wed Mar 22, 2017 11:26 am
The "Installation and Release Notes" button on the downloads page has a link to the last version that supports XP :D
PicoKev
Post by PicoKev » Wed Mar 22, 2017 1:08 pm
Thanks Martyn I had missed that link. :oops:
Just goes to show that every day is a school day! :D :D
Kev.
victor2k
Post by victor2k » Sun Mar 26, 2017 7:46 am
Using w10 64 bits OEM with all updates I can't detect my 4425(is detected as WestBridge! in DeviceManager)
Using w7 64 bits OEM I used 6.12.7 without any issue.
Someone know how to solve this issue?
Thank you.
Post by Autonerdz » Sun Mar 26, 2017 3:20 pm
Yes. We have seen this several times. From Device Manager, update driver and manually direct it to your PicoScope folder to find the driver.
victor2k
Post by victor2k » Mon Mar 27, 2017 10:49 am
Solved using your solution.
Thank you
