Vauxhall Insignis 2010 2L Diesel cam/crank shaft
1ststartgarage
Post by 1ststartgarage » Fri Mar 03, 2017 4:42 pm
We have a 2010 Vauxhall Insignia EX CDTI engine 2.0l Diesel with a starting issue, EML Light on engine fires & stops and fires and stops. with cam sensor discounted engine will start, traction control/ABS light on. The only fault code stored are P0344 Camshaft position sensor performance and P0016 Crankshaft position intake camshaft position not plansible current
U0100 Lost cams with ECU (ABS)
Sensors been changed no different, ECU been sent for testing no fault found, we have scope reading everything kicking in as it should.
Need help please :cry:
Re: Vauxhall Insignis 2010 2L Diesel cam/crank shaft
Post by KimAndersen » Sat Mar 04, 2017 10:24 am
Could you upload some of your scope captures as this will show us much more than you ever can write down here - hopefully !!!. :wink:
Kim
1ststartgarage
Post by 1ststartgarage » Mon Mar 06, 2017 12:02 pm
This is the scope reading I have
